Using My VR Lab, a teacher can multicast Umety modules and 360 videos to their students' VR headsets. The whole class can experience the same content simultaneously, or groups can be configured and be given different content at the same time. The teacher can also monitor what each student is seeing in their headset while they are exploring the content.
The teacher can play, pause, and stop the content at any time.
Start a VR Lab
From your teacher account at
app.umety.com, choose a class, then select the
My VR Lab tab. You should see all of the students in the class listed.
Have Students Join the Lab
Each student should sign in to My Classes on their headset, click Join Lab in the bottom menu and select Enter Lab for your class.
In your teacher account, you should see the students' status change to Connected and the dot turn green.
If a student isn't showing that they are connected, have the student exit and re-enter the lab in their headset.
Select Content
Click on the blue + button in the upper right corner to choose the content to play. You can select any of the content that has been added to your class.
Play Content
Once you select your content, you will see the options to play, pause, and stop the module. You can also click on the "i" for more information about the content.
Groups
You can arrange students into multiple groups by clicking and dragging the bottom right corner of a student's tile.
Now you can select content to play for each group with the blue + button as described above.
Related Articles
Scores & Assessments in Umety VR Content
There are a number of ways in which VR can help fill gaps in the learning process. It can provide more instances of working with, or interacting with, a concept. It can foster higher-order thinking and help to develop critical thinking by way of ...
Umety VR Content Library - Overview and List of Modules
Umety has an ever-growing immersive content library of 650+ modules for STEM, Educational tours, and Language learning, which engages students with concepts, closing the gap between knowledge and understanding. Our VR content is specially aligned by ...
Labelling Content
You can create and apply labels to the content to keep it organized however you like. Students can see these labels when they log in to their classes in a browser or in the VR headset. Once you have added content to a class, you will see a Labels ...
Curriculum Alignment with Umety VR Content Library
The modules in the category of STEM are aligned to the major curricula across the globe. The curriculum alignment as per the school requirements is done by our content mapping team who is responsible for the selection of topics relevant to major ...
Adding Content to a Class
Content can be added to a single class or multiple classes at once. To add content to any of your classes: 1. Select a class from the My Classes page. 2. Click the Content tab to view the modules you have assigned to your class. 3. To add content, ...
